- Oct 7, 2006
Of course they did
Fortunately no. They put the old one backSo, did they charge you for the ECM?
That's rare, usually they keep running up the bill till they find what's wrong. Good for you.Fortunately no. They put the old one back
in.
If the shop doesn't figure it out I'll try it. They're brand new though. They were replaced two weeks ago when all the issues first started. Thanks!Look at the spark plug wires while running, in pitch dark if possible.
Could be a loose ground wire or wire crossfiring.If the shop doesn't figure it out I'll try it. They're brand new though. They were replaced two weeks ago when all the issues first started. Thanks!
The van is in the shop right now. They are going to look at it first thing in the morning.It's dark out now. Just look.
You may not be able to go out tomorrow.
Wow, moron mechanic. I had an oil change done at my Isuzu dealer, they forgot to put the cap back on the valve pan cover. Drove it to a job and started it up, ran fine for a couple minutes till it warmed up. Sprayed oil on the manifold, started to smoke pretty good, thought it was on fire. Called the dealership to get a cap and some oil. The mechanic that brought it over said that this happens more than you would think.Got the Chevy back today and it’s finally running good again. When the first shop put the wires in they used pliers and tore the insulation on most the wires. They used some silicone to try and patch one of them. Also the #8 wire was barely attached to the plug which was the spark I was hearing during the misfires. Got some new wires and the idle is back to normal.
View attachment 97784 View attachment 97785 View attachment 97786 View attachment 97787
There are no more mechanics these days. There are just people who take off old parts and put on new parts. They do this until they solve the problem or the customer gets fed up and walks away.
