Coffee stain,
steamron
Ron
The expert's may have to answer this one,
Is there a difference if a coffee stain (or tea) is permanent if the coffee spilled is very hot, or it has added flavoring, sugars, etc.
Thoughts,
Reactions: Giorgio
Sure, the fabric content makes a difference too, and whether the coffee was high octane or unleaded, or a vente or a large..
Or hot or cold..
Reactions: Living The Dream
Meter Maid
The Undetective
Some cheap coffee can contain a bit of food coloring. Some creamers also do and that can cause a problem. So you’ll need something to cut through the sugary stuff, possibly a red remover and then an oxidizer for the actual coffee stain.
Reactions: Giorgio
I actually did your method to one of my church peeps about a decade ago. Hot tea. I told her to quit carrying it around. I don’t think I ever got called back😂
Reactions: Giorgio
Coffee can be complicated at times. Decaffeinated coffees often have artificial dyes added to them. The hotter coffee is, the deeper it can penetrate into the carpet and fabric. Creams and sugars can further complicate it. I usually start rinsing with a neutral cleaner to remove anything that is easily removable. Then I use a liquid coffee/browning treatment which is a mild reducer. Spray heavily, let dwell and you should see some immediate change. You can repeat if necessary. If it still doesn't budge, use a oxidizing coffee stain remover. I seem to find the most effective ones are the 2 part peroxide/ammonia ones, though I have had good success with Harvard's Stain Magic and even with Sally's 40 volume peroxide. The commercially prepared products for carpet cleaning often contain other ingredients to make the peroxide more effective than 40 volume by itself.
Mr Brightside
Jay Wags
I seem to find that if the customer hasn't done their own cleaning or science experiment on it before I do Ill get it out. unless its tumeric then I won't
icleancarpetz
Rafael Samson
You guys are behind the 8 ball leaving money on the table.
I talk em into painting the carpet. ive made million$
