assuming there are no tacks............I'd probably hit it with a torch for a few seconds.........after Justin posted what they use during assembly
Reactions: Rob Grady
I’m waiting on an aluminum pipe to be made to hook the blower up to the waste tank
Looks like a lot of unnecessary work
You should be cleaning carpet
My main rig has been at Jondon getting 2k hr. service for the last 2 days. So I took off thur-sun to work on this and hopefully get it ready to clean this sunday.
As for your asshole comment...it's necessary. I paid a good price for the van and machine, and My schedule is full.
It's ok, I made it work. I'm excited to see this thing in action later this weekend
After lubing the pressure regulator and fixing several water and antifreeze leaks after first test
  • IMG_3985.MOV
    118 MB
First testing with blower attached.
I got the heat around 185-200. The thing that puzzles me is when I pull the trigger, it holds heat pretty good. When I let off trigger, the heat drops fast. Any ideas on why it’s doing that?
And I think it needs a new thermostat because the anitifreeze is only about 135f at the coolant heat exchanger. Isn’t it supposed to be around 160-175?
  • IMG_3988.MOV
    151.6 MB
  • IMG_3989.MOV
    48.1 MB
Is it bypassing water when not triggered?
