- Oct 22, 2012
- Name
- Ron Marriott
Get to my first job this morning, hook up my water hose, fire up my propane heater, bring in the hydra-force and hook up the pressure hose, try to start the engine and the blower is stuck. Have to disconnect everything, go back to the shop and get my back up hydramaster, which I have been using the past week. Guess, I had a little moisture in the blower last time I used it. Has to disassemble the silencer, the belt guard, loosen off the motor mounts and back off the belt tensioners, remove the belts and put a pipe wrench on the pulley to move it. Luckily, it moved easily. I got some wd40 in there put the belts back on and fired it up and ran a little more wd40 through it. Real pain in the ass to have to do so much work just to be able to turn the stuck blower, As I am reassembling everything, I think, if only there was a nut on the blower pulley. I am going to have my next door neighbor weld one on. If it ever happens again, I should just be able to reach in with a large wrench and work it loose. More importantly, at the end of the day, don't forget to spray some wd40 or other lube in the blower port. Usually a 10 second burst is good, let the blower run a couple of minutes to burn it off.
