Mar 18, 2008 #2 Kevin B Member Cleaning Professional Joined Nov 17, 2006 Messages 1,457 Name Kevin Bunce Just so you know, they don't work so well if they don't run through the Heat Exchangers. I've used Prochems product with good success.
Mar 18, 2008 #3 G Glynn Member Cleaning Professional Joined Nov 26, 2006 Messages 231 HM Clearwater rinse.
Mar 18, 2008 #4 S SRI Cleaning Member Cleaning Professional Joined May 4, 2007 Messages 1,131 Name Anthony Firmani Glynn, Do you just mix the clear water rinse with your fresh water an run it in a normal dilution and clean carpets with it? or do you just circulate a more concentrated solution through?
