What is the greatest 14" wand ever?
Now that I have the power to use it, I think I'd enjoy have a 14" wand on hand for wide open spaces. People speak highly of the Devastator wands but they are out of stock with no indication of when they'll be available. What is your favorite 14" wand? 1.5" or 2" tube? swivel or no swivel?
MarkieMark
Mark Franco
Last time I was posting honestly TMF kicked me out of their group..... 😉. I have 3 from Mike that we carry in our trucks daily but I gotta admit for 14" head max flow is the top of my list especially at $850 on sale. Can't wait to green glide the maxflow since I love the new design that lets you get right up near the wall.
That thing looks saweet. Love the custom colors for our business too. How about that sale price [:
You're too slight of build to be pushing the 2/14 all day long to save your customers a few minutes of dry time.. the aluminum head and swivel just makes it worse as it's unneeded weight..
Slight of build, you're such a gentleman Mike. What do ya think about a 1.5/14 for me?
Whatsup with a 10' whip? I've been using a 25' whip. Is the 10' just for better recovery?
My Simple wand would be ideal for your commercial work and big areas
it's the Chosen, that cleans 25%ish quicker
Great tips Mike. What do you mean by "balanced" vacuum? Do you just mean more vac power balanced with maneuverability (compared to my 25' whip with less vac power), or something else entirely?
Got any video demos of the Simple wand Mike?
Prochem Titanium. I've used most of them over the last 20+ years. IF you can find one for sale, you won't regret it. I don't regret not spending the money on a swivel. I never saw potential on one of those wands, but they do get under a bed a little better if you're OCD on getting every spec of skin dust off the carpet that a vacuum cleaner can do just as good.
The two wands I keep on my truck are the Prochem Titanium and Mikes 2jet wand for the smaller areas.
  • Love
too big for him, but a cut down 4 jet version might work
Mike's Simple Wand is a 2 jet 6 flow, the Prochem Titanium is a 6 jet 12 flow, both 14". Does that mean the Prochem puts out 2x as much GPM? Does the Prochem also have more impact and shearing power? I imagine with 6 jets they will be closer to the carpet fibers, does an 02 jet that is closer to the carpet have more shearing power than an 03 jet that is significantly further away?
That is incorrect, the OEM flow setting for the prochem titanium is six flow.
Same amount of water being delivered in two different ways, which do you think has more impact?
My bad, read somewhere that is had 6x 02 jets. How many jets does it have?
Great to know, thanks Mike. If only I could hold these things and compare the feel of them. Hopefully I can make it to the next MF and play with a bunch wands.
You're a beast. Do you use an APO on your TM? What size is your waste tank?
100gallon tank. shutoff switch is around 70gallons. I do have an APO on both of my machines. I'm a little paranoid about worrying if my jets are gonna get clogged up, so that's why I prefer that size jet. I've had the clogging problem when I had 1flow jets on my previous tools.
I see. There is an APO on my machine but it does not work. Hasn't since I purchased it. Seems like it would be handy on bigger jobs though. I'd like to get it running. I noticed I go through water and fill up my waste tank disproportionately faster just going from 400 psi to 500 psi when cleaning carpet.
I have inline filters on all my wands. I do have to clean them often. All my jets are 2 flow. Never had a clogged jet. Now I'm not sure if its because the jets are large enough where it's not an issue or if it is because of my inline filters.
Sounds like you're using old hoses in the internal rubber is falling apart creating you all these issues
Those hoses could be in your truck mount and not just your pressure line
  • Love
Do you mean what keeps creating crud that gets in my inline filters? Good to know. Makes sense.
I was thinking of going to my local supplier/service center early on a day off and one by one replacing all my internal truckmount hoses. He has a crimping press and high heat/high pressure hoses in every inner diameter with every type of fitting I could need. If I have him make me new hoses and fittings for most of my lines I'll prevent many failures and have backups ready to go for the future. I'd remove and install them all of course...
