The most powerful portable available?
Im intrigued by the monsoon's
low weight and cost.
88 lbs seems rather Light and maybe incorrect. And the price is a steal.
However, i had a porty with the same body design and couldnt get it up stairs safely. Rotovac may have solved this issue by placing the solution outlet and drain in the front.
Did anyone use it at MF?
Yes and I reported elsewhere that I used it and the thing is a champ
Sharky
Bobby
Teflon glides??? For portables, make some teflon slides that fold down from the back of the porty to slide up the stairs so you don't have to roll it up each step. One major reason I rarely touch my cimex. It's almost impossible to roll up a staircase with water in it.
How do you make Teflon glides?
