The best 47 blower or higher slide in
I think your machine has a 406 in it.
Calling it a 46, one would think it is a step up from a 45 but smaller than a 47.
Not the case. It actually has less hg. and less cfm than a Sutorbilt #3 or a Roots 36 blower.
The hf 406 is capable of 321 CFM at 14 inches hg. At 3600 rpm. More than enough for residential and light commercial.
It's funny they use the same blower in the peak, and say it has 400 cfm. Oh k
All depends on rpm and where the vac relief is set. The advertised max specs is usually not the same running in real life specs.
If we’re getting that much out, we’re getting the Cimex out anyway🤷🏼‍♂️
Reactions: DAT
Trip Moses
IMOL
Trip Moses
The best machine on the market for the O/O
Is that an 🍎 feature?
no....your phone does it too.
When people see themselves "normal" it is slightly unfamiliar to them because they normally only see themselves in the mirror. This isn't about angles. Just the image reversed.
and your phone likely automatically filters you with "beauty face" btw although they have turned it down over the years (I think). You're way uglier than your pics would suggest....
edit for link
edit2: looks like they turned it off as default but you have clearly been using it
Reactions: SamIam and hogjowl
Hey Mikey
Any cc’ers you know have that cleanco slide in?
KevinD
Kevin Dumas
What was your point?
My point was calling the blower a 46 instead of a 406.
Wouldn't wand someone that has maybe a machine with a 4M or 45 blower thinking about buying a
370ss thinking it has a bigger blower than what they currently have and getting disappointed in the end
because it is basically a #3 or 36 blower.
