- Mar 25, 2007
- Name
- Roxy
Hi,
I just had to replace my blower and now I have another problem. My wast tank is leaking.
It's an older (1999) CDS machine.I have had a couple of leaks already I was able to drill out the hole,put a bolt and washers through it and that worked. This time the hole is at the front edge where the waste water drain valve is. I drilled out the hole again and was able to thread a bolt into it with a washer again but it's so close to the bottom that I can't even get a nut against it on the other side. So I siliconed the washer to the tank from the outside and then epoxied the washer in place so it won't come off even if the threading of the bolt or the silicone fails.
But and when I look into the bottom the whole first 10" is is pretty deteriorated. Could be only a matter of weeks before i have another leak. So I did some research and I found two coatings that are self leveling and might work.
One is a Sherwin William product called Armor Seal 650 SL/RC
The other is sold by my local marine supply store and it is called Glove It.
I know eventually I'll have to take out the tank and have it repaired. A local shop can fabricate some kind of tub that fits around the bottom of the existing tank for about 500.- plus whatever LPM in spokane would charge to take the tank out and then reassemble it.
In the meantime I really would like to get my tank sealed so that I can at least make it through the winter.
Have you guys used these coatings? Do they work? Could they work even permanently?
If it do this should I coat the whole bottom of the tank instead of just the front part?
Hydramaster is not selling replacement tanks anymore. Is there another option?
That blower cost me almost 4000.- so I'm really looking for a solution that I can swing at this point.
