- Mar 25, 2007
- Name
- Roxy
My 1999 CDS machine has an aluminum waste tank. A few years back I read about anodes and i bought a zinc block from a marine supply place, hooked up a copper wire to it and bolted it to the inside panel of the tank.
Over the past few years I have seen that block deteriorate a bit and I'm thinking that it must work.
My tank still seems to deteriorate because I see little pits on the walls inside of the tank and what it dries out there is a white powder on those pits. Similar to what you see on neglected car battery terminals.
I called a supply place that sells anode rods for water heaters and they told me that the anode does not need to be connected to the tank and the more surface the better.
So my questions:
If surface makes the difference and not mass, would a large sheet be better?
Is there a source for sheets of solid zinc, like 12" X 8" maybe 1/2 to 1" thick?
Would it be effective if I just drop a plate like this into the tank and not connected it to anything?
Would that anode plate need to be cleaned periodically to be effective?
Has anybody here tested a system like that on an aluminum tank?
So my questions:
