pretty much the worse floor material ever.
porous/pitted Limestone...
Like living on stale wonder bread.
half cleaned..
Homeowner has done everything wrong with the floor.
-Uses a Shark Steamer
-String mops
-Applied a topical coating three times over 9 years without proper cleaning.
and never mopped up the excess topical in the grout line after they made mud with it...
http://youtu.be/noBN531F7Q0
Only scraping/grinding or a gel based coating stripper is going to get it off..
Reactions: glenboy
cameron demille
That is a very expensive floor. Pillowed Beaumaniere Limestone, we've done quite a few of these.
This is where Klenztone does a good job.
as far as the topical, that last little bit here and there is the hardest to get off. It sucks they had to put so much crap on there.
What product and technique would you use to get off that residue Cameron?
Our Stripper/ Oxy mix didnt even budge it.
problem is he does not know what he applied. other than it looked Milky.
I have to think they contaminated the topical with dirt from the un-steam cleaned floor. They admitted that they did not wipe up some of the puddles in the grout lines....hence the brown plastic all over....
floorguy
Doug
kick the diluttion a litler higher....no oxy only stripper....
and then wait, wait..
scrub, rinse and repeat......
only thing you can do
Connor
Connor
Think that's bad, I have a customer with that stuff in his bathroom. The floor in front of the toilet is pissed up and smells like....... Wait for it...... Piss! They didn't understand why I didn't have some "magical piss removal spray" and actually said "don't you plumbers have some spray that will clean thar cleans piss off your tools". I said we don't pee on our tools to mark them, so, no.
I'm just kidding.
Reactions: tmdry
Willy P
Willy P
I'm just kidding.
Yeah! Everyone knows POOP is more effective! Duh!
Reactions: Connor
cameron demille
Methylene Chloride
for the dirt, Klenztone i the best, but you have to protect everything else.
I have a client with 40,000 feet of this that I service several times a year.
I think I'll stay away from the methylene chloride...tried some real strong floor stripper and not a damn thing budged..looked like hell...grout saws and THEIR knees are going to have to do it.
floorguy
Doug
didnt budge???
then it aint acrylic....
urethane of some sort, and bonded to cementious grout lines......uhhh yea
yeah, they didn't know. they did have a empty bottle of a Bona stone topical but they said only the maid uses it.
Hubby said the crap he used was milky...
oh well...I did my part.
boazcan
I recently used this to strip an old urethane based sealer on 1400 sq ft of pavers. I am looking forward to trying this on something similar to what you have. This stuff worked very well with 15-20 mins of dwell. http://www.dadseasyspray.com/contractor-grade
RESPIRATORY PROTECTION: If the exposure limits are exceeded a NIOSH approved full facepiece supplied
air respirator or self-contained breathing apparatus should be used. Selection and use of respiratory
equipment must be in accordance with OSHA 1910.134, 1910.1052 and good industrial hygiene practice.
VENTILATION: Use with adequate ventilation (equivalent to outdoors) to maintain exposures below the
occupational exposure limits. Use explosion proof equipment where required. Open doors and use fans to achieve
good air movement. If possible, use local exhaust to remove vapors.
GLOVES: Wear impervious gloves. Contact glove supplier to determine correct glove for this product.
PROTECTIVE CLOTHING: Impervious apron, boots and other clothing are recommended if needed to prevent
contact or if splashing is possible.
EYE PROTECTION: Chemical safety goggles recommended.
OTHER PROTECTIVE EQUIPMENT: For operations where contact can occur, eye washing facilities should be
available.
no thanks,
boazcan
no thanks,
If you were coating the entire floor, then maybe. But just grout lines will not be an issue. It works good. I was outside with the pavers. :cool:
Sent from my DROID RAZR HD using Tapatalk 4 Beta
