Pocket Pressure Popper Thingy
That thing, do you guys know of a little tool we can carry in our pocket to release the pressure on our quick connect when a valve accidentally gets opened and no tool is connected.
Sometimes there is so much resistance I can't slam a male quick connect in it and have to go to the truck to turn the pressure down. Major pain in the butt...
I dont carry a little tool, i carry a male quick connect fitting. If you can't pop the female open under"normal"pressure (300-500psi) you have one of 2 things working against you (or both) first a leaky/ weeping valve. Second cheap ass Chinese quick connects. If the valve is still weeping when turned off, if possible with an allen wrench, tighten seat around the ball if not replace the valve with one that you can. Even then if the valve is on under pressure and you turn it off and try to poumd the quick connect in it still might not go if your using cheap ass quick connects. I use foster quick connects and most the time i can still tap the male in on the sidewalk with the valve open and connect 2 hoses together while one is still under pressure. So in conclusion get yourself a Mikey's valve(the one with an on/ off not the round knob one) and while you're shopping if you don't have um already pickup a few sets of good quality quick connects and your problem will disappear
KevinD
Kevin Dumas
He said "accidentally opened it" We have all done it no matter the valve.
Usually you can flip the wand upside down and while squeezing the trigger force it on unless you are running extremely high pressure.
Another trick it to take a small blunt object and rap it with something against the shut off cone.
There is no tool
There, I got to the point without 10,000 words nor any BS
I appreciate your being so straightforward.
But, there is a tool. I saw it with my own eyes down at the last supply store I was at. The owner even tried selling me one. It's a magical little pocket pressure popper thingy.
they live
Steve
It helps to open the valve all the way too.
Then call that dude.
Reactions: they live
It was probably on the same shelf as a left handed smoke turner, bacon stretcher and a high volume cooperarer to the throttle waddle for a ducks ass. If you got an extra 70bucks laying around, ill sell ya something you can really use. A right hand metric crescent wrench ( add 10.00 for left hand version)
  • Wow
they live
Steve
Whatever you find it will be in the van when you need it because you will get tired of carrying it and not needing it.
Its the law.
Calling a retail store to inquire about their products so I can order them elsewhere feels disingenuous. The ride there is 2 hours round trip. And he doesn't put out a warm hearted and welcoming vibe like you do.
I think all you guys would really like a pressure popper thingy.
Its the law.
Do you guys have a toolbag or something that you carry into homes when you first get there? I do. It has head lamps, tweezers, scissors, and a lighter for fiber id on furniture, notepad, and a bunch of really important and very professional doo-dads. Put the pressure popper thingy in there.
By the way guys, I typically can slam a male quick connect in there. But today it just wasn't happening. Maybe I am becoming weaker. I just turned 40. Could I be rapidly declining?
Well apparently I owe you an apology. According to my supplier they do make the tool you speak of. He says it looks like a quick connect without a poppet and instead of having female threds it has a flat area that can be smacked and a side hole for the pressure to bleed outa. Now ive seen and used a tool of that description for super high pressure hydraulic systems 3000-10,000psi that are positive displacement and can't be bled down without it. that had a screw to release nut they are a hundred bucks or so. but never heard of one for carpet cleaning nor would i ever imagine that anybody would consider a 100.00 tool to relieve pressure on a carpet cleaning hose. Not even me and i have a special tool for everything imaginable. Heres a picture of my drawer of just specialized disconnect tools! So sorry for mocking you. But if youre really looking at high pressure hydraulic disconnect tools and thinking seriously about buying one please consider also picking up one (or more) of my special metric crescent wrenches. They now come in metric and standard combos🥸
Screenshot_20260326_154606_Google.jpg 20250119_143541.jpg Screenshot_20260326_153406_Facebook.jpg
View attachment 134555 View attachment 134556 View attachment 134557
I sense that deep down, you really want a pocket pressure popper thingy. Maybe I'll get one with some radioactive green color on it 🙃 and you'll see the light. I'll keep you posted Dwain-o.
For now I need to sleep better and eat more power foods so I can have the strength to slam a male quick connect into my tool and save myself 2 long and stupid trips out to my truck.
Rob Grady
Rob Grady
I run my everything from the unit to the tools that I am using with the male as lead. Ball valve shut off at the end of my lead hose. That way I can shut valve, press poppet against some thing solid to release pressure and continue. I find it nicer to reel in the hoses also.
That's a great idea. Have you had problems with the male quick connect getting dinged up and not sealing properly? I can imagine it would take a beating when retracting the solution when packing up if one isn't careful.
Just drop your water pressure as low as you can
Leave the valve on
Then slam a male connect on the hose. Does less damage to the qr
Leave the valve on
That's what I did. But the end of my solution line was on the second floor of the home. It was a painfully long walk to the truck and back upstairs, twice!
Ya know for 40-90.00 and approximately 1hour of work you can install a remote start stop on your machine. I installed one on frankinstien, loved it so much i installed a second one on the pump. I can remotely shutdown and turn back on the whole machine or just the pump from up to 1900' away. Cant pop the quick on?...... push a button on a key fob and hook it up push the button again and resume work ask Nate, he's got one on his machine and can give ya the name of the guy that came up with this idea.(not my original idea) That guy has one on his hydramaster cds too. They start at around 20.00 i prefer this 35.00 model, it has a much longer range. I wired mine to the wastetank float switch so it tricks my machine onto thinking the wastetank is full and shuts down just like it would if the wastetank was full. Much much cooler and far more useful than a pocket pressure popper thingy
Screenshot_20260327_211843_Gallery.jpg Screenshot_20260327_212055_Gallery.jpg Screenshot_20260327_210945_Amazon Shopping.jpg Screenshot_20260327_210836_Amazon Shopping.jpg
Rob Grady
Rob Grady
The reason why I run this way is because of damage to the potential damage to the FM qconnect when it would be dragged backwards to the reel. Generally though, I walk the lead end back to the vehicle and retract the hose so the ends don’t get damaged.
