- Oct 7, 2006
Real world cleaner ^
Three out of four hospital doctors preferr an edging tool.You should send it to Professional Testing Labs to examine the dust/dirt/lint particles in your oreck bag.. See how much of it is carpet fibers..
My dinosaur Windsor XP12 that lays flat to get under beds, with a on-board hose tool does a great job.. Same vacuum hospitals and hotels use..
Mabye when Mikey mows his lawn he doesn't weed eat ever. But never missed a single blade in the center.
How about the main entrance of those 2bedroom duplexes. It's a freaking sand box right at the entrance, because none of them take their shoes off. If you don't have the aggressive weight combined with the beater bar, you're just getting the junk on top of the carpet.
Why can't you edge with a Truck Mount hose cuff?
I yam what I yamThose Popeye forearms say otherwise
I learn something everyday.They all say "Lift Away" on them somewhere, but only get the one that allows the tank to lift off and make the unit become, essentially, a canister vac. You can vacuum under beds and it tight places withit in this mode.
That would mean to a lot of people that they are dead.Vacuum heaven
It's feather light, if the lack of edging is bothering you @hogjowl you can attach the small cannister vac Mikey also loves (for furnature) with some tape or zip ties and boom...problem solved. It will need two cords now, so it's sorta like a portable but with low amps you can plug them both into the same outlet.
The best one has a real good vac hose too.They all say "Lift Away" on them somewhere, but only get the one that allows the tank to lift off and make the unit become, essentially, a canister vac. You can vacuum under beds and it tight places withit in this mode.
https://www.amazon.com/Rotator-Prof...31713&sr=8-3&keywords=shark+rotator+lift+awayI've heard a ton of raving about shark vacuums on here. I need a new machine for my house. Which shark do you guys recommend?
