Marble magic without Diamonds.
Just Stone Scrub, a Red pad and Cobbs enhancer.
BEFORES..
other sink
AFTERS
This area was covered in build up
ridiculous counters for a messy family of five with zero housekeeping skills and no budget or desire for real polishing...
We also cleaned their shower, regrouted the wall/floor joint and cleaned and sealed the travertine floor
Still $2100 worth of work to be done there.
it's amazing stuff, dwell time really does wonders. My concrete counters are next. Lots of mineral build up around my fixtures.
I could have sworn I ordered more of it....:winky:
Rob Fairfield
Rob Fairfield
:clap:Great job Mike. Those pictures speak a thousand words. How many cases do you nee?:winky:
Do you use some kind of buffer tool to rub that stuff in or on or whatever?
If so, what kind, type, etc.
Rob Fairfield
Rob Fairfield
The glass sealer is a two step wipey system. It is Ted and Cameron's process. In fact it is under their Easy Stone Care label.
Cool ... I met Ted and Cameron at the Chevron Station yesterday.
Not ...
cameron demille
I am Cameron, Ted is Ted
It is a two part system. They are basically pre-soaked wipes. You wipe on part A, let it sit for 2 minutes, then wipe on part B. After that dries (2 minutes), you clean the residue off with a glass cleaner and soft cloth.
soap scum can still physically accumulate on the surface, but it makes it much easier to wipe away.
This product works for Glass, granite, porcelain, stainless steel and other polished metal fixtures.
Here it is
http://www.easystonecare.com/Single-Use-Granite-Sealing-Wipes-from-Wipe-n-Seal-p/wns12.htm
Reactions: hogjowl
ted mcfadden
Here it is
Rob is distributing these as well.
Reactions: Rob Fairfield
