- Feb 4, 2016
It's Canadian, how professional can it be?Yes, it won't bottom out with the tire hitting the wheel well. This is a professional suspension shop who knows what they're doing.
Well, it's not Damonized. No fire extinguishers were necessary.It's Canadian, how professional can it be?
no speed bumps in the UNDERGROUND GARAGE?Come on @anon ! that should be picture of the day. Not Mike's ugly finger pointing at a boring $99 Lowes rug
No, My van parked in front of the Goldfield Hotel should make TPOTD
I have seen speed bumps in some parkades, not in mine.no speed bumps in the UNDERGROUND GARAGE?
What they did is basically flatten the springs on a hydraulic press. When you look at these vans stock and empty, they look like the rear end is jacked up. There is more than enough space to lower it a bit without impacting the load capacity. The carpet cleaning unit installed is towards the front center of the van and tends to push the front springs down and not affect the rear very much. Cleanco pro unit. Even if I were to install a fresh water tank, the space for it is still more to the center of the van. They have re-arced the springs, installed new shackles and u-bolts, checked where the bump stops are. Apparently, a very common procedure here with guys trying to get their vans into underground parkades.There is only so much room between the frame and axel unless they notched the frame. I would be interested in seeing what they did.
Just get a promaster. It sits low enough I can step in without ripping out my pants crotch.What they did is basically flatten the springs on a hydraulic press. When you look at these vans stock and empty, they look like the rear end is jacked up. There is more than enough space to lower it a bit without impacting the load capacity. The carpet cleaning unit installed is towards the front center of the van and tends to push the front springs down and not affect the rear very much. Cleanco pro unit. Even if I were to install a fresh water tank, the space for it is still more to the center of the van. They have re-arced the springs, installed new shackles and u-bolts, checked where the bump stops are. Apparently, a very common procedure here with guys trying to get their vans into underground parkades.
Too tallJust get a promaster. It sits low enough I can step in without ripping out my pants crotch.
...yeah like we need criticism from an okie.
