Hydroforce Sprayer Issues
My hydroforce injection sprayer will not quit spraying even when not keyed. I pulled it apart and cleaned the filters and screens but it didn't help. Any tips or troubleshooting advice greatly appreciated!
Can this valve assembly be bought individually?
If you look closely at this picture you can see a busted seal, but where did it come from?20201003_125939.jpg
valve
or you can get the handle/trigger valve assembly for $37
looks like that 10 cent oring might fix you up though
Tried several different O-rings today and it made things worse. I think they were to fat. I think I'll order the replacement valve and pull it apart to see what the proper seals and O rings are. Then I can have a rebuilt spare on hand.
  • Sad
Matt Middleton
As time passes, we try to have at least one replacement for every contingency possible. Butler parts, sprayer parts, belts, etc.
Just buy another spray gun from a car wash supplier.
www.dultmeier.com
Don't over think this
This isn't hard
Don't buy a overpriced gun from interlink
I think they are more expensive at the website you provided but I'll check into it a little more. I think heat is what ends up causing these injection sprayers to fail. If they have better heat resistance it will be worth it
