Do you claw every known soda or coffee spill?
What is your technique?
How about on glue downs?
If enough was spilled to discolor the carpet backing.Do you claw every known soda or coffee spill?
Wand clean the area using slow passes. Pre-treat the spill with a tannin stain remover/detergent. Apply the claw and use a gun jet to apply cleaning solution to the carpet around the claw. Stop spraying when no more color is observed through the clear plate. Remove the claw when no more moisture is observed through the clear plate.What is your technique?
Doesn't work as well due to lack of airflow, but spills aren't deep into plush carpet either. Quick drying is preferred, soil hiding is sometimes required.How about on glue downs?
