How do YOU prepare your van or fleet for winter?
[h=1]Truckmount Winter Readiness Winter is just around the corner. Be completely prepared for cold temperatures. by Dennis Russell[/h]December 7, 2012 By Mikey P Leave a Comment
The instructions on how to prepare a vehical for winter are pretty straightforward.
Although they recommend taking the vehicle to an authorized mechanic to ensure that the wipers, blades, battery, belts and tires are all in good condition, there are only two crucial concerns mentioned: Make sure the recommended amount of antifreeze is in the radiator and that winter windshield wiper fluid has been installed. If only it could be so easy to winterize a truckmount extractor.
Although the consequences for improperly preparing an automobile and a truckmount for winter are similar—potential risks and serious damage to the motor, pumps, valves, hoses, and just about all engine components, to name just a few — getting a truckmount ready for the colder months is more involved.
And there are usually far-reaching consequences for carpet cleaning technicians who depend on their truckmount in their work: Loss of the machine due to freezing temperatures means no money until repairs are made.
Just following the holiday season is usually the busiest time of year when we take phone calls from panic stricken truckmount owners whose truckmounts have frozen up over the holidays. Often times, many of our customers work right up until Christmas, and then take an extended break where they park their vans between Chrismas and New Years Day.
Prepping the machine for winter
Although each truckmount manufacturer will have specific recommendations for their equipment, the following are general steps that will likely apply to many, though not necessarily all, truckmount machines:
• Get familiar with requirements. Long before cold weather arrives, carpet cleaning technicians should be fully aware of what steps they should take to properly winterize their equipment. Sometimes serious and costly problems may arise if winterizing steps must be taken at the last minute, just hours before a blast of winter arrives.
• Select the proper antifreeze. Before discussing how much antifreeze to use for winterizing the machine, it is necessary to discuss what kind of antifreeze to use. The major differences among the various brands are the “corrosion inhibitors.” Some brands of antifreeze are formulated with very high-quality inhibitors to provide the needed level and types of protection for the truckmount and its components. In contrast, a lesser quality brand may not contain the additives and corrosion inhibitors to thoroughly and properly protect the extractor. Many manufacturers recommend and install 100 percent glycol-based antifreeze and will likely recommend the continued use of this type of antifreeze for the machine.
• Drain any mix tanks, water boxes or containers your truckmount may have. Some machines will have a drain valve to release antifreeze; others will require the pump to be on and water to be released out of the wand. Some machines will automatically switch off when water is drained; others must be manually turned off. It should also be noted that antifreeze can be toxic, and most communities have regulations on how it is to be disposed.
• Fill with antifreeze, in the amounts recommended by the manufacturer. With some manufacturers, this may be 100 percent antifreeze, not diluted with water. With other machines, it may be a 50/50mixture of antifreeze and water.
• Either turn the ignition key on or start your machine, depending on the procedure necessary to circulate the antifreeze through the machine. The antifreeze must be moved through the entire system and be completely circulated, as this will allow it to protect all components that are affected by water.
Be prepared
Carpet cleaning technicians should carry antifreeze with them during the winter months, in case more must be added.
Wands and hoses should be stored indoors when not in use; this also applies to virtually all tools and chemicals.
If at all possible, when not in use, the truck or van should be stored in a heated garage. If you do have to store your vehicle in an unheated garage, or outside, and you are depending upon an electric or portable heater to keep the temperature above freezing, make sure you purchase a remote temperature sensor alarm. These relatively inexpensive devices can be easily purchased at Amazon.com. You simply put the sensor in the van, and the alarm in your home (so long as the proximity is within the manufacturers recommended distance). If the electricity goes off, or your heater runs out of fuel, and the temperature in your van falls below freezing (32 degrees fahrenheir), it sets off the alarm in your home.
Winterizing vehicle-powered units
There are two basic types of truckmount systems:
• Slide-in systems are powered by their own engines and are bolted into a van or truck.
• Vehicle-powered or clutch drive truckmount systems (CDS) use the truck’s or van’s motor to power the extractor.
Most of the suggestions and steps already discussed apply to slide-in systems that have their own motors and pumps.
Vehicle-powered or clutch drive systems do not have their own motors so, for the most part, their winterizing concerns are tied to properly winterizing the host vehicle.
A ‘do-it-yourself’ job?
Most manufacturers will provide detailed instructions on how to winterize their equipment.
However, some truckmount manufacturers recommend that their machines be winterized at an authorized service center.
For those technicians who lack the time or mechanical expertise or who are just concerned that the winterization process be done correctly, taking the equipment to a service center at your local distributor may be the best option, especially if you are going to be shutting down your machine for a week or more.
The most important thing is to simply be aware that there are specific steps that must be taken to keep the equipment running properly throughout the winter and up and ready when warmer weather returns.
Royal Man
Relating to this winterizing story.
Does anybody know of a wireless thermometer that I can leave in the van and read from inside my house.
I haven't found any that work.
I have foil backed insulation on the entire inside of the van and I wonder if that is the problem.
been only a few times I have had to throw a heater in the back...this year will be the normal....same thing I do everyday.....get out and shut the door and call it a day..........
Royal Man
I guess every cleaner doesn't live in Arizona,Nevada, California and Florida.
Nope....we have to put on our big boy pants and deal with some killer heat for a few months.....but the rest of the year is worth it.....
GCCLee
We are fortunate and can park inside otherwise it would be the old heater and extension cord.
Chris A
Fired the heater a couple weeks ago
