- Oct 7, 2006
- Name
- Jim Martin
I think this is what you were asking about the other day...Mine was sticking so I took it apart and cleaned it up....
remove cover and take out the upper right and 2 lower bolts........
I grab the entire thing and push it in and out until it breaks free and comes out
clean and polish up the rod and I take a round wire brush and clean out the hole
I put my extension in the tail pipe to make sure the door inside is open and put some high temp grease on the rod and put it back into the hole
bolt it back on .....I always paint the top of the stick red so I can see it easy from a distance.....
also...if you start it up and there is a little blow by coming out of the lower HX you can take the cotter pin out of the rod and separate it from the stick and turn it to tighten the flapper door more if needed....
I normally have to do this every 150 to 200 machine hours.....
