- Feb 14, 2014
- Name
- GregO
I have been using a dual blower custom made truck-mount machine for the last 23 years. With dual blowers it is a very effective dual wand machine. I know that some of the newer machines that claim to be dual wand suffer a bit when one of the operators disconnects a hose or lifts their wand off the carpet since they are using a single blower. With my machine it doesn't matter what my worker or I do with connecting or cleaning as each vacuum is completely independent. Our high pressure is provided by a single Hydracell wobble pump. There is a slight decrease in both pressure and heat when two wands are used but we compensate by turning up the pressure a bit and it works fine when cleaning. I have accumulated approximately 14,000 hours on the machine and have done 1 engine rebuild, 2 Hydracell pump rebuilds, 1 Sutorbilt Blower bearing replacement, 4 alternators and several drive-belts. Not too bad for 24 years of operation.
These are some specs:
Engine: Nissan A1500 4 cylinder gasoline engine
Blowers Two Sutorbilt 4MV blowers
High Pressure Pump: Hydracell D10
Heat exchangers: Engine coolant and exhaust heat exchangers.
Pump-Out: Dual pump-out pumps
I am considering building a few more of these machines using a newer engine such as a GM Vortec 1.4L. Just wondering if you guys think there would be a market for these. I believe I could keep the cost lower than many of the newer large Truck-mount machines available.
Thank you in advance for any input you may have................Greg
