Does timing matter when it comes to using fans to dry as you clean?
Lee Senter has done some testing that convinced him that if the snail or down draft fan is placed within the first five minutes of cleaning it will dry the carpet MUCH quicker than if placed 20 minutes or longer
Letting the rinse water drip down to the backing being the premise...
I'm into rocket science
if no pre-spray used, I'd hypothesize the reason isn't water dripping down to backing, but more to do with surface tension/wetting agent(s) time on fiber making it "wetter" deeper into fiber before the big blow evaporation process starts
Ed Valentine
Ed Valentine
IMHO, and experience, "if" the carpet fibers are "completely cleaned" and rinsed with very good extraction performance, that this timing would not make a difference, period. After all, prior to drying with a fan, the fibers should completely be damp, and not just surface cleaned.
Hoody
Steven Hoodlebrink
Bowling Green, Ohio
Role
Years of Experience
21
I could see that. Could have to do with evaporation potential as well. Assuming the carpet will be warmer than the ambient air(assuming cool and dry with AC or warm and dry with heat) within the first 5 mins, applying airflow to it quickly before it cools could provide more evaporation at the start. The airflow from the air mover would also help push the initial humidity out of the area and help the EP too because the moisture has to go somewhere.
Edit: shut up Marty.
Rob Grady
Rob Grady
My RVJR gives the fastest unassisted drying times available. Even on barbers.
DAT
Bill Cheryl
I always open windows and turn on the fan before I poop. I believe in being proactive about it.
DAT
Bill Cheryl
Me neither. Not needed here.
Living The Dream
Swani
I leave air movers behind at 95% of my jobs. Being able to see how the carpets look and dried down has really helped me dial in my methods. I get very few wick backs now days. On FB I see a lot of cleaners bragging about how they don't agitate or do dry strokes, but I gurantee there's a lot more wicking going on then they know about.
Not doing dry strokes is just plain lazy. Especially with modern glides. I am often doing a few more dry strokes just because I can.
Matt Middleton
Matt Middleton
I agree.
Matt Middleton
Matt Middleton
Could be that a fan placed at five minutes rather than twenty has fifteen more minutes of drying time.
Tell Lee he's welcome.
Pet peeve. I can't stand to see a blower not doing its job. Get them running asap.
I think it was @Lee Stockwell that said on here "the water you leave behind not doing dry stokes, is just as dirty as the water in your waste tank."
I always found it curious that some seem to think that your extraction system removes all the dirty water and only leaves clean water on the carpet.
