DETERGENT OR ACID RINSE?
juniorc82
I HAVE PRETTY WELL STUCK WITH TH ACID RINSE UNLESS IT IS A NASTY ASS RENTAL OR RESTRAUNT, THEN I USE SOME CTI PROPOWDER HOW ABOUT YOU?
Doug Cox
Doug Cox
I use detergent all the time.
TimP
Detergent also. I have found it cleans better and doesn't cause resoil.
Blue Monarch
Dirk Wingrove
Mostly Hydramaster Clear Water Rinse. I'll run an emulsifier here and there, but not all that often.
MicahR
Micah Richardson
How about an acid detergent?
Prochem's All Fiber Deep Clean or Bridgepoint's Endzone have both worked great for me in the past.
Most of the popular acid rinses contain surfactants.
Rex Tyus
It depends on how much scrubbing I want to do. I prefer to deep scrub and acid rinse,yet that is more expensive so as of late I have been using more emulsifyer.
You want a cheap clean? I CAN DO THAT.
You want the mack daddy best of the best, I CAN DO THAT TOO. :mrgreen:
E
everfresh1
c_adkins said:
SoapFree by Masterblend
I always use powder detergent since most of the carpets I do are trashed. I ordered some soapfree masterblend haven't tried it yet how does it work on trash out carpet?
Chris A
Don't expect it to work miracles, I should re-phrase. I use Soap Free on my residential carpets. For trashed out rentals, residential, or commercial I use Pro Chem Heat Wave.
Kevin. McCreary
Kevin McCreary
I mix an acid rinse 50-50 with a high ph emulsifier,
then add some rug doctor rinse in too so its soa approved!
I cant figure out why my jets always plug up.
Rex Tyus
You need bigger jets dude. :mrgreen:
ascrubabove
If I'm spraying the 12.5 ph lava on a trashed carpet I will acid rinse, other than that o2 system all the way!
E
everfresh1
Thats some crazy mixture :?: I think the acid rinse and and emulsifier are working against each other thats why your jets are clogging.
Art Kelley
everfresh1 said:
[Thats some crazy mixture :?: I think the acid rinse and and emulsifier are working against each other thats why your jets are clogging.
This is why subtle humor doesn't play well here.
Louis
Louis
I use judsons 02 rinse most of the time. If its bad I will use CTI extreme clean. I like filling up the jug and not having to waste what I didn't use that day.
