Clear sealer of choice?
Why do you use your favorite sealer
  • Have you tested it and found it to be the most resistant to oils
    Votes: 0 0.0%
  • Did you find it's the most resistant to every day cleaning agents the home owner may use
    Votes: 0 0.0%
  • Does it last longer then others tested
    Votes: 0 0.0%
  • I dont believe in sealing
    Votes: 0 0.0%
  • Is it the cheapest
    Votes: 0 0.0%
  • The most expensive so therefore the best
    Votes: 0 0.0%
  • Its the only one your supplier sells
    Votes: 0 0.0%
  • Smells the best
    Votes: 0 0.0%
  • Easiest to use, who cares if it works
    Votes: 0 0.0%
  • Total voters
    2
Tell me why you use the penetrative sealer('s) you do.
BUSY BEE
I like TOG's Clear Guard SB the most (mainly on grout), works good and has no odor. I also use Stone Pro Ultimate Pro which works well. Looking at Dry Treat for the future.
BUSY BEE
My testing was applying 2 coats of TOG SB on half of a 18x18 honed (800) travertine, pouring beer, wine, soda, ketchup, lemon juice and veg oil. Same on my grout board. I left the stuff on for maybe 15 minutes, wiped and it didn't penetrate. It obviously penetrated the unsealed sides and staing the grout and the stone.
Ron Werner
Ron Werner
when applying this sealer, is it sealing the tile itself, the grout, or both?
Is it applied all over like applying protector to carpet?
BUSY BEE
On ceramic or porcelian tile/grout, just the grout lines. On stone, the tile and the grout lines.
rhino1
Chris Bolin
Usually use Stonetech,(really good sealer, kinda pricey, cool bottle that impresses the customers) but I am using Aquamix sealers this month to try them out, I got 10 gallons of the Gold Sealer at a truly good price.
