- Oct 7, 2006
- Name
- jim
Have you ever run a CDS unit like this?
The Cleanco was running fine for about 5 minutes and then lost power, went out to the van and the Savana was idling. Shut everything down and started over again and the same thing happened after a few minutes. After doing this several times it quit revving up completely.
I have an '07 Savana with a Cleanco Compact 47. The local distributor couldn't get it running and determined it was a GMC issue. The Cleanco throttle control module will only call on the GM ECM for more rpm's if certain conditions are met - transmission in park, parking brake set, can't touch service brake or gas pedal, GM error codes MAY affect operation.
The Savana has had a wonky oil pressure sensor for the last year so the local GM dealer replaced it and could not see any reason why the Cleanco shouldn't run. Van went back to the distributor who cleared any error codes the high tech way (disconnect battery) and was able to get the unit running. Drive the unit home, the next day Cleanco won't run. Van went back to GM per distributors request to check for error codes , none found.
Driving back to the distributor tomorrow, hoping to get this resolved. Gonna pray to the spirits of Ed, Garry and Judson to channel some good energy up North in the morning.
