ChipFest
FB7777
Let me look into shipping cost. I’ll get back to you. One of the wands is 10” shorter. Custom tube from Tom. I’m 5’9”. It fits me better. The other is stock. I switched to 12” heads with 2” tubes.
Never mind. I want 14 devs stock
Reactions: Trip Moses
steve_64
“Wedging” which button?
Are you referring to the front panel engage rocker switch?
They are dirt cheap to replace and take 5-10 minutes to install
I've replaced it. I'm glad chip takes my calls. I've called butler too. They say it's in the van so I've replaced rear axle seals rotors and pads the steering gearbox ND everything else that was loose. It still won't run unless I wedge it all the way on.
I still need tires too.
Trip Moses
IMOL
Trip Moses
Put a hard surface glide on your SS14... POW!
I just brought the ss14 with me to do an empty. Second time I’ve used it in a year. Came with the new TM. Big sigh….. I don’t know. I think it may actually extract better than the Devastator.
Sounds good for Boyle he's 5 foot 6 doah
you didn't have one a few years ago when you were humping Tom's wand as the greatest evah??
Larry, exactly when did I take over Green Glides and the shipping and handling department and complaint department and start paying attention to everything that was wrong and greatly improving. Almost the entire lineup, exactly?
And it was when I put a brush glide on both of those wands. It became very apparent which one had more air rushing through the head by its ability to slurp the water up off the floor, suspended one eighth of an inch up.
Reactions: SamIam
when John went down
so, help me understand what else you're saying.
That Tom's wand was better until you improved glide fit on the SS14?
Reactions: hogjowl and SamIam
when John went down
exactly, the OEM glide leaks, rockers back and forth and is waay to wide open...
FB7777
Ok is what about operating costs?
Pretty sure Mikey’s corporate “ Shedquarters “ is paid for so I bet the margins are pretty fat
it’s been super hot out in the trenches for you boys, but it’s apparent you’ve been hydrating with your haterade
  • Wow
Reactions: SamIam
FB7777
But the more money you make, the less your opinion matters … objectively.
another observational brain turd from Mort ….
from now on I’m going to only seek the council and opinions of poor people
those that grow companies and successfully monetize their time can’t be trusted to offer advice
I’m glad you’re making money. Nothing wrong with that.
I may be wrong every 200th full moon about CC equipment but you nor anyone else here have never seen me lie to sell anything
If that’s what your reasoning gained from my statement, then your opinion is suspect too.
  • Eyeroll
Reactions: FB7777
Excuse me. Was your comment about Tom’s wand at Chip fest a lie or a convenient half truth?
