- Oct 7, 2006
I don’t care
What is the fastest way to remove the moisture from the air?If they remove moisture from the air, rugs will dry faster as the ambient air is drier. Things in drier, warmer air tend to dry faster.
Otherwise, it would be a waste of time installing dehumidifiers on flood jobs.
Air movement of course. BUT, for a small potatoes operation like mine, Ron’s, or something Damon is setting up, a dedicated dry room with mega heat, fans, and a pulley rack is bloody expensive.What is the fastest way to remove the moisture from the air?
I am aware of the difference between indoor and outdoor humidity. That's why we take readings in both in order to determine open or closed drying on water damage jobs. If I was in Phoenix or Vegas, I would just open the windows and turn on the fans. I can get my rh down to 25% indoors in my shop by using dehumidifiers. That's a lot drier than the humidity outside today. 55%What is the fastest way to remove the moisture from the air?
In some cases it may be
use an LGR or dessicant dehu they dont need temps that highAir movement of course. BUT, for a small potatoes operation like mine, Ron’s, or something Damon is setting up, a dedicated dry room with mega heat, fans, and a pulley rack is bloody expensive.
If a guy is only doing 5-10 rugs a week, what’s the overall cost to run the dry room with forced air heat, fans, and lights? Don’t forget, the goal is to have the room between 100-120F.... that’s not cheap.... what’s he making off of the 5-10 rugs?
True, but why waste electricity trying to slowly freeze/thaw moisture from the air when you can spend less money and time to heat the incoming air and expel the moist air?If they remove moisture from the air, rugs will dry faster as the ambient air is drier. Things in drier, warmer air tend to dry faster.
Large furnaces on trailers have been around for a while for use on larger jobs, and even dehu makers are selling portable gas and electric furnaces for flood work. The fastest and cheapest way to dry a structure, you just have to remove items that would be damaged by the higher temps.Otherwise, it would be a waste of time installing dehumidifiers on flood jobs.
I've seen the Cambridge unit. If I owned my shop and wanted to expand, I would consider it. Makes perfect sense. I'm still a rug hack at best.What works for you works.
If you decide want or need faster drying as a smaller shop, it might be worth looking at a small electric furnace like the one Phoenix sells. You could use it for flood work as well. A larger step would be a gas powered portable like the Dri-Eaz 3600 that could also be used on-location.
If you get to a larger volume, Tom is the outlet for the in-plant Cambridge heaters, but those require a gas line with a slightly higher than normal gas pressure to run.
What's the deal with the Cambridge units? I keep hearing people mention it. It's just a heating unit, nothing special about that. Or is it special? Or are we just all dumb carpet cleaners?I've seen the Cambridge unit. If I owned my shop and wanted to expand, I would consider it. Makes perfect sense. I'm still a rug hack at best.
It's the combination of heat and ventilation. It provides a continuous supply of warm dry air while exhausting the moist air outside.What's the deal with the Cambridge units? I keep hearing people mention it. It's just a heating unit, nothing special about that. Or is it special? Or are we just all dumb carpet cleaners?
So it acts as a Dehu at the same time?It's the combination of heat and ventilation. It provides a continuous supply of warm dry air while exhausting the moist air outside.
Only in the sense that it removes moist air and replaces it with warm dry air. You have exhaust fans in the dry room pulling out the moist air while the heater is filling it with warm dry air. It's not just a heater, it's an airflow system as well. You end up with continuous warm air circulating around the rugs. They have lots of videos and diagrams on their site and YouTube. They claim that it reduces drying times to aprox 6 hours.So it acts as a Dehu at the same time?
I learn something every day
Mikey will want to sleep with you.I was thinking about coming down in the 36’ Diesel Pusher motorhome I have sitting in my shop parking lot. What could possibly go wrong.
You're crazy. LolI was thinking about coming down in the 36’ Diesel Pusher motorhome I have sitting in my shop parking lot. What could possibly go wrong.
Waiting on parts.You're crazy. Lol
Hows the van?
Actually Damon, I meant the motor home....
