Jan 4, 2009 #1 E easy1dave Guest My pump started leaking on the bottom where the blue housing goes against the brass.still was abble to finnish job but pressure kept dropping.Is this a easy fix?Thinks in advance.David
Jan 4, 2009 #2 Doug Cox Supportive Member Cleaning Professional Joined Dec 17, 2006 Messages 4,950 Name Doug Cox Sounds like you need to rebuild it. Cat pumps are pretty easy to do.
Jan 4, 2009 #3 Jim Martin Supportive Member Cleaning Professional Joined Oct 7, 2006 Messages 10,877 Name Jim Martin you need a rebuild kit for your type of pump... just make sure that you are really careful and pay attention to how each part comes off because the seal are directional...
