- Nov 29, 2017
- Name
- Chris
I was cleaning at 210 degrees after my machine was running for around 5 minutes.don't take a pic of a temp spike
look at what it is while cleaning normally
and if you have a meAt thermometer, put it in the jet spray at the distance it hits the fiber
and really get a surprise
I usually get the best heat after my machine has been running for 10 minutes or so, under load.
Even if the thermometer was off by 10 degrees, I was still cleaning at 200 degrees with a 12k machine.
I run 2” from the tank to my 2” wand. No inline filter.
My blower filter NEVER gets clogged and I simply put a Mytee Piglet over my waste hose as it empties.
This system worked great until I started using a 1.5” wand.
Today, I used my new Dang wand and my dry times were ridiculous.
With my little Boxxer 318.
I can buy another new Boxxer 318 for 11k.
The machine I bought from Orlando is set to run at 3400 rpm... that means it produces 40 CFM less than a 370, or so. The btu is about the same as a 370.
For 11k.
