Butler chemical pump
Jester
Is there any way to bypass the chemical pump on an older butler and get it to draw chemical a different way. Right now I'm running juice through my system.
thanks
If you want a good chem pump, and don't mind spending some money, buy one of these:
http://www.catpumps.com/pdfs/access/6300.pdf
You need this on a Cat 435 or 335 pump. The last number 5 denotes the special manifold used by Cat for this application.
Talk with Cat or Butler first to see if it will work with other pumps.
Jester
That looks like what I have It's a 93 it hasn't worked since I had it I got it used. My meter knob is stuck to so that for sure is part of my problem.
thanks for the post
Jester
I got my knob loose and actually had fluid being pulled through it for 3 min then it died on me and couldn't get it running again.
Buy a new needle valve for it, a rebuild kit, new hoses, a new Dwyers (since they suck air in with all the little stress cracks) and give it a shot.
Cat thinks that 4 bolt version was worth gold. When I was at Cat last Feb we were working on mine and I told them I wanted a new 4 bolt style. They gave me the price..and it was more than a whole new 435. They looked into the pricing for 3 days thinking it was a typo...but couldn't come up with anything.
Chad
I disagree.
been there done that.
give me an emulsifier any day.
And if you prevaced you would need to run ten pounds of Clean It to get er done
Jester
I ordered a new Stainless steel valve from idealvalve.com when I took the old one off it was broke off in the closed position.
Hate to disagree with the boss, but I agree with Greenie.
Years ago we used plain water rinse to ensure no residue.
After switching back to an emulsifier our customers (we also) saw a distinct difference in the results.
The only difference between The vegan and Chavez, is Chavez is right.
There is more to this biz than "soft" carpet.
K
Kevin Hamer
Maybe I should rephrase that, done properly fresh water rinse is the best.
bob vawter
Grassy Knoller
bob vawter
To get back on topic...jus run a chem draw line thru a Dwyers..... into a mix jug
07?
Steven make sure you're driving, if Bob is driving, you might go back to the future! :p
TimP
I have to say that I've run acid rinse for quite a while. And I switched to emulsifier and what a difference it does make. I don't even have to scrub anymore. A good prespray and emulsifier is all you need unless it's just rat nasty. I've saved so much time cleaning it's just unreal.
