Blower louder after getting rear-ended
carpetcleaner
Rob Litwin
After getting rear-ended, the blower on my TM doesn't sound the same. It was a minor fender bender with no visible damage to the TM. Can the bearings have been damaged?
Rob have you checked the mounting bolts to the unit. Is it possible one or more could be allowing vibration causing the blower to sound different. Assuming it's a slide-in.
carpetcleaner
Rob Litwin
It is a slide in. Nothing is loose. There are no visible signs of damage. The blower seems to now have louder bearing sounds.
Reactions: Desk Jockey
Matt Middleton
If the blower to the muffler is connected with flexible hose it could have torn. Even with a small tear the blower changes its tone. I have blown out chunks of old blower hose while working and the volume of the blower screams. Fairly easy fix.
Reactions: Spurlington
I'm wondering, is this truckmount belt or coupler on the blower?
carpetcleaner
Rob Litwin
It has a coupler and is mounted in a trailer.
I has checked the alignment of the coupler, the exhaust is secure and intact.
It seems to be working fine, just has a different sound. I guess that I will wait for something to break.
