- Oct 22, 2006
- Name
- Johnny
Anyone ever see a driveline transfer case powering a blower in a cargo van? The weak link in commercially-available CDS systems is the belt-driven clutch. With the blower turned by the driveline (a cheap, readily-available 4WD transfer case could be used but a higher gearing might be needed), more torque would be available to turn a blower much bigger than a 47, which seems to be the limit with electric belt clutches. The blower could even be mounted on the transfer case in the chassis to eliminate another power transfer link.
Or what about a hydraulic pump on the transfer case or the front of the engine crank (with a bypass valve) to a hydraulic motor on the blower?
Good night.
Good night.
