8+ flow on Evo
no idea on flow on that wand but if you want to keep those wands from chattering and grabbing (and losing lift) you should try a Teflon glide
I'm running 6 flow on my Dev and SS Titanium
If you had a 48 or larger blower Id try * flow, I suppose
Hack Attack
Dan
its a light skittery wand as has been mentioned, a teflon glide improves it and a 4 jet manifold helps increase it weight and improves its edge to edge coverage...
I still only pull it out on carpets Mike would encap or if Im tired or in pain.. hell I should use it all the time 🤔
Meter Maid
The Undetective
I added the shear kit from Bristor.
Currently has 4 1.5 jets.
Reactions: Hack Attack
