100% VLM ???
SteamwayPro
George
George,
I got a feeling this train, gonna be pulling into the depot?🚂
When they make the change on this board?
I think the back-and-forth is going to stop?
All good things must come to the end?
If we live long enough and if this board stays active? it's gonna be fun to watch some of the young guys switch to VLM!!!🤔🙂
PAD LIFE FOR EVER!!! ✌️
I thought the changes already happened
And the Pro Helper got temporarily removed
SteamwayPro
George
Frank the problem with Carpet Details is it's a powder
And yes I know Carpet Details does mix rather easily
When I don't know what I'm going to use for a job it's a pain mixing it up at the job
And if I run out on the job then I got to mix it up and it's wasting time
Much easier just using a liquid like VacAway Encap Green 7.5 PH for the nice easy jobs that's similar to Carpet Details
When I know I'm going to use Carpet Details I mix it up at home and take it to the job saving me time
Liquids are just easier to work with
I used VacAway Encap Green with Deotnator (Peroxide) on that job
Reactions: frank fratto
SteamwayPro
George
And does Carpet Details lose strength
It says on Website it will never lose strength even after mixed
Can I mix up Carpet Details and not use it for 24-48 hours
Have you ever done that
frank fratto
frank fratto
I like Carpet Details so much that carry 15 gallons per made up at all time. {keeps mix up forever}
I think it's the best all around cleaner that is safe for everything![cotton wool silk tile and grout]
And so easy to bump up when you need to.
Vacaway is a great product too and very convenient!
In the VLM world there's a lot of great products now!
TM guys can't use everything we can because they're Worried about FOAM 😯
{Heat and hydrogen peroxide, TM guys BE CAREFUL}😯
Reactions: SteamwayPro
SteamwayPro
George
VacAway makes a great booster. It's called Spot-n-Boost and they have a green version Spot-n-Boost Green. I always use the Green version because it has less odor. You can add it to any encap at 1-2 oz as a booster
I mostly use it as spotter for Soil Filtration, ink, make up, etc and I mist it on filthy traffic lanes and it does a beautiful job. I love Spot-n-Boost Green
I going to add Spot-n-Boost to Carpet Details the next time I do my Apt Complex and see what the results are
I love VLM !!!
frank fratto
frank fratto
I love VLM !!!
I'll need to get me some of that spot-n-boost..." I've never tried it"
Let me know what you think about it with Carpet Details? 🙂
frank fratto
frank fratto
I love VLM !!!
I can't help myself ! I've always bumped my chemicals with something?
My Father must have done it? lol ... It's just habit 🤷‍♂️
Why, if they don't need it? Your father had crappy chems! He struggled to get good results probably without being a chemist booster. Chems are so much better these days for sure.
SteamwayPro
George
IMO if your going to use Carpet Details on filthy hard to clean polyester it needs a boost
Steve Smith at VacAway found the secret to cleaning polyester
VacAway cleans polyester better than anything I have tried
Double Trouble with no boost and very low odor is an outstanding cleaner of polyester
THANK YOU VacAway !!!
Funny, he worked in a lab full time. Cleaning business part-time
That's why he could mix plug and play. I too have boosters, but have found that if I need to use a booster
I need to change chems. If I need peroxide, don't use a booster, get a chem with it in it. Blah blah🤷🏼‍♂️
frank fratto
frank fratto
Chemical manufacturers
start out with a good mix then
they slowly make it weaker and weaker.
then they come out with a new one mix#2 new and improved😂.
It probably was just original mix formulation🤔
Why would I pay someone to put hydrogen peroxide in my chemical, when I can control that myself.[THINK ABOUT IT]:headscratch:
frank fratto
frank fratto
I'm pretty sure chemicals were pretty good maybe very good in the 50s-60s-and the 70s. They got things very clean!
Then TM came along and they had to figure out how to make chemicals without FOAMING up the waist tank,
that has took years to figure out. to make quality chemicals that don't foam?
I have a pretty good memory for the past 45 years?
frank fratto
frank fratto
You said one key word to prove my point. FOAM!🙄
What's wrong with foam?
We all drank the Kool-Aid from TM manufacture, chemical companies,
foam is just fine in the VLM world haven't seen any signs of residue in the last 10 years[Trust me, I've been looking👀]
Matter of fact, it's been just the opposite carpet stay a lot cleaner!!! 🤔
SteamwayPro
George
I HATE Soil Filtration !!!
I HATED it when I was HWE and I HATE it now that I'm VLM
This one in a 55 Plus Housing Community has it in every House that has the original Builder Grade carpet. When new customers call I ask if the carpet looks dirty along baseboards and they ask how did you know that
I did one today. Luckily most of the old carpet has been removed but One Bedroom , and the loft still had the original carpet. The carpet was spotless but it had soil filtration
I always tell customers before I start that it will be better but not perfect and they understand. If they don't understand I don't take on the job
I used VacAway Spot-n-Boost Green, a drill Brush, a Grout Brush, and a thin piece of aluminum to protect baseboards from drill brush on the soil filtration and VacAway Encap Green with Detonator on the carpet
Run the CRB in straight up to the baseboards when I can and used a thin Microfiber Bonnet on Odyssey to get up as close as possible to baseboard
When I went out to my Van to leave a neighbor asked me for Business Cards. I'm hoping she won't call
frank fratto
frank fratto
This one 55 Plus Housing Community has it in every House that has the original Builder Grade carpet. When new customers call I ask if the carpet looks dirty along baseboards and they ask how did you know that
I did one today. Luckily most of the old carpet has been removed but One Bedroom , the loft still had the original carpet. The carpet was spotless but it had soil filtration
NICE JOB!!!
frank fratto
frank fratto
George,
do you charge extra?
SteamwayPro
George
George,
No because when I was explaining everything on the phone she said don't worry about the soil filtration. Just do a regular cleaning. She said the carpet is 25 years old needs to be replaced
But even though I wasn't getting anything extra I still try to make it look better not perfect but better
I also did that Bedroom on the first floor. Carpet is only 5 years old
LESS water MORE agitation !!!
frank fratto
frank fratto
I would probably do the same thing.
It's not always about the money?💲
I like a good challenge!!!
SteamwayPro
George
Yes it's not always about the money
That's why I have a lot of long time customers
Big job tomorrow. Furniture Area Rugs and Carpet
Been going to that house every year for probably 15 years
Everything is always spotless. Easy money
Going to use Carpet Details on Furniture and Area Rugs
Double Trouble on second floor polyester carpet
I love VLM !!!
