100% VLM ???
bob vawter
Grassy Knoller
bob vawter
NO, I don't run in your circles, I've heard of it now.
Circles....EXACTLY.....OR MORE commonly known as orbits!
I really thought EVERYONE has heard of this by now......we've been tracking this interstellar object close to a year now.....
PURPOSE:UNKNOWN
However my belief is.....they have to eradicate this pesky species that are about to introduce a radioactive substance into an otherwise perfect creation......
AND MORE-FURTHER......YOU....should realize if you haven't learned of this phenomenon......how many other Things are you un-aware of????????
And yet even further more...let's say this really does exist AND have beings wit billions of years of intelligence and technology......what does that do to the Jesus story?
Yep starting to likeVLM can't pull the hoses in anymore trying to to sell truckmount van and other equipment I was doing good for a while but have run out of steam not in the truck but ME hope to make it to January to 84 so I'll just do small jobs to help pay bill.No retirement but in stock market and NOT good there but there is light at the end of the tunnel. I just have to find the tunnel.
Stud
SteamwayPro
George
Not gonna start this debate all over again, but if you hwe, you know you didn't have to #flood most carpet to get it clean. Chems and agitation are doing the same thing you're doing following up with an additional step. Some don't do that🤷🏼‍♂️
You should know by now I take a jab at HWE every chance I get :biggrin:
I did this job today. One chair, 2 Bedrooms, Hall, Living Room. I used 3 gallons for all of that. I rinsed the chair with water and that is not included. I haven't been HWE for 6 years now so I don't really remember how many gallons it would take to do that using the HWE Method but I do know it would take many more gallons than 3
How many more gallons 10 ??? 15 ??? I don't know but compared to VLM, HWE uses and WASTES many many more gallons of water
That carpet is a cheap Polyester. I used 2 oz VacAway Double Trouble and 4 oz Detonator (Peroxide) per gallon on chair and carpet
I'm starting to like that Sapphire Portable Upholstery tool. It uses too much water but adding a shut off solves that problem
LESS water MORE agitation !!!
Reactions: royalkid
SteamwayPro
George
I remember you liked and were using Carpet Details
Are you using Carpet Details with VLM
I rarely use it anymore. It just doesn't clean polyester good enough for me
If your new to VLM VacAway or Excellent Supply sell the BEST encaps
jessi
Jessi Lopez
Yes I leave the MESSY Look and I like it
If I thought there was something wrong with the MESSY Look I wouldn't post pictures
I don't worry about perfect groom lines. When the customer starts walking on the carpet those lines will disappear fast. They're not deep lines
I use a 10'' CRB with soft brushes. That carpet is thick nylon and the lines are mostly just on the surface because the CRB is light and has soft brushes. A carpet brush/rake leaves deeper lines than a 10'' CRB with soft brushes. A 10'' CRB grooms the carpet better than a Brush or Rake. My opinion
I never get any negative comments from customers but do get criticism from other cleaners. If I start getting negative comments from customers that's when I will change my opinion on the MESSY Look
I'm more concerned with getting the carpet clean and dry than groom lines
I like the MESSY Look !!!
Stretch this carpet
View attachment 133018View attachment 133016
What’s that tube on the back of that portable? Some exhaust muffler thingy to help catch all the crap air exhaust that comes out of that machine into the customer’s air???
SteamwayPro
George
It's a muffler that catches noise
Without the muffler it's loud and very annoying
With the muffler it's probably 50% quieter
When I'm prespraying and scrubbing furniture I have machine off
I only have the machine running when I'm extracting
I like that Sapphire Portable Upholstery Tool
Meter Maid
The Undetective
If I thoroughly scrub and then rinse carpet, use a clean white pad after the rinse and said pad is mildly dirty, then what’s the difference if I only pad that particular carpet and keep cleaning with fresh pads until the white pads are only mildly dirty, just like if I had padded it after rinsing?
Is that carpet somehow cleaner if I rinse, even though the final pad used after rinsing looks exactly like the final pad I used if I had padded that carpet only?
