WAND JET QD'S
Farenheit251
It would be great if someone came out with some little QD's for quick changing the jets.I'm running 5 1.5's on my CMP. Alot of the commercial nylon carpets that I do in restaurants dry so fast with no effort. I only need em dry in 10 hours not 1-2. Might as well be running 02's or 025"s. Probably still be dry in 4 hours and save me some work. Also on some I clean in the morning and they open for lunch some 01"s would be nice, also good for some olefin berbers. Brian E
GRHeacock
My opinion- keep the same jets and lower your pressure, or raise your pressure for more or less water.
That's what I do with a single size 9606 jet.
Gary
Carry two wands Brian.
One w/hi-flow and one for quick dry
Why not make your own with the tiny QDs like on the Multi-Sprayers.
Would they leak, I wonder?
Be easier to clear them when clogged/fouled , that's for sure
The pressure wash industry already does this, and with color-coded tips.
Even now you can change three tips in less than three minute, if you have need.
