- Aug 1, 2007
The builder will tell us the cfm and the heat potential. Why don't they rate the noise levels in decibels? Wouldn't you be interested in knowing before you bought your next machine?
Walt said:The builder will tell us the cfm and the heat potential. Why don't they rate the noise levels in decibels? Wouldn't you be interested in knowing before you bought your next machine?
Walt said:I installed an additional silencer. That helped a lot. But it is still not a quiet machine. Impossible to dual wand or run on high doing town homes. Far to loud. It's fine in a standard residential in single wand mode. Dual wand mode is a little much but doable. Frequently on short runs I'll run the machine at 1250 rpm and then it's just fine. I was cleaning until 8:30 on friday in a really nice neighborhood with no complaints.
Hollywood said:Walt said:I installed an additional silencer. That helped a lot. But it is still not a quiet machine. Impossible to dual wand or run on high doing town homes. Far to loud. It's fine in a standard residential in single wand mode. Dual wand mode is a little much but doable. Frequently on short runs I'll run the machine at 1250 rpm and then it's just fine. I was cleaning until 8:30 on friday in a really nice neighborhood with no complaints.
Doesn't that cut performance all to hell? I was told the lower RPMs would put stress on the pump. My manual says to cut downs the RPMs for doing upholstery but my mechanic says don't do it.
Anyone have any input on this?
