travertine filler?
jimmyolas
what kind should i get and were can i find it. need it by next tue. need to fill holes and some cracks.
any suggestions on technique for cracks? thanks jimmy
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
I would go to a flooring store that has products for installers. Don't know the names in each area, but they are around most large cities.
You might also try David Gelinas at 1 800 Marble Guy
The filler will likely be an epoxy.
Scott Warrington
The High Chapperal
Don't fall for that "Filler" bs.
Just get some unsanded grout in the color of your choice.
At some Acrylic fortifier and your good to go.
brzelt
Kennesaw, GA
Bruce Zelt
Agree with Mike except if it is a polished travertine.
Then you will want "Travertine Spackle" from Granquartz. Blends in well plus will be shiny when completed.
jimmyolas
i ended up getting some travertine fill from stone pro. the big stone dealers and installer stores did not have any type of fillers.i got a dark and a light. should last a while. 22 $ each. jimmy
