Nov 10, 2009 #1 B Bucey Guest I going to clean some tile in my house with the hard surface wand. Is hot water just fine and what about resealing the tile grout? Never done this before and could use some info.
Nov 10, 2009 #2 C Carpet Cleaning Fool Guest Re: Tile cleaning pro The floor will turn out better if you apply a tile and grout cleaning solution prior to using a hard surface tool. Some products even require dwell time for the chemicals to be most effective. Hot is good. The hotter the better.
Nov 10, 2009 #3 B Bucey Guest Is 240 hot enough and 900psi? Is there any need to treat the grout after cleaning?
Nov 10, 2009 #4 Mike Pailliotet Administrator Joined Oct 6, 2006 Messages 117,272 I opened up the Tile and Grout room for you. Don't forget to get some sleep tonight.
