Auction Rotovac 360XL carpet Brush Head
MikeysBoard
Bob Long
Description:
Up for grabs is a new RV360XL Brush Head with your choice of vacuum port styles.
For older units with the 1/2 horse motor you'll want the Teflon Glide option. The metal shoe style will bog down on thicker piles.
If you plan on purchasing the new 3/4 horse machine you may want the metal shoe option for added agitation.
Both options clean much quicker and deeper than the non brush heads.
These heads are NOT just for commercial carpet. The brush material is soft enough to be used on just about any synthetic residential pile that is dirty enough to justify using Rotary Extraction.
We strongly recommend breaking in the brushes before using on your first job.
Either take the vacuum shoes off and run the head on rough concrete or asphalt for 20 minutes or run the complete head on a piece of very stiff Olefin glue down style carpet for 45 minutes to an hour. Look for the bristles to be permanently laid over.
Free Lower 48 shipping.
Retail value is $595 for either head.
Bid Now at Cleaning Classifieds
** You must create an account in order to bid on items. Your Mikey's Board credentials will not work. Click the following link to create your account: Register **
Oh crap it's for the xl my bad someone outbid me quick I'll send you the $5 back
mirf
David Mirfin
Is the one for auction 3/4 Horse?
If you have an older unit you can choose the teflon glides which work fine with the 1/2 hp
Or you can upgrade to the new motor for $150, swap it out and use the metal shoes..
Hell I might of had to by the XL to go with it! And I'm already about to get rid of my hoss!
