Jul 31, 2013 #1 jmo Supportive Member Cleaning Professional Joined Apr 11, 2011 Messages 350 Name Jeremy I have not noticed this before. My 360i is squirting water out of the center bolt hole I cleaned the jets and its still doing it. Anyone know if this is normal?
Jul 31, 2013 #2 Mike Pailliotet Administrator Cleaning Professional Joined Oct 6, 2006 Messages 117,380 center bolt hole? picture would help..
Jul 31, 2013 #3 T TimM Guest I think there is a check valve in there. RP-269Check Plug$9.38 that is from rotovac on its site
Jul 31, 2013 #4 jmo Supportive Member Cleaning Professional Joined Apr 11, 2011 Messages 350 Name Jeremy Right in the center if the cleaning head there is a bolt that has a hole in it.
Jul 31, 2013 #5 jmo Supportive Member Cleaning Professional Joined Apr 11, 2011 Messages 350 Name Jeremy I fixed the problem with a 3 dollar plug from a hardware store. Took out the check valve and put in a plug.
Aug 1, 2013 #6 John Olson Member Cleaning Professional Joined Oct 9, 2006 Messages 6,281 Name John Olson That's what Rotovac did to fix the problem to
