Epoxy Floor Cleaning & Maintenance
SMRBAP
Anthony
Anyone have any rec's for cleaning & maintaining an industrial grade roll on epoxy floor? Just the epoxy, was not cleared.
I have a tenant 5680 with the nylon brushes, it's not doing so well. Cleaning dirt we track in from the vans and roll around with the lifts and pallet jacks. I was thinking maybe trying pad drivers and a non-aggressive pad?
Any advice on what pads or brushes and chem's (and dilution) to use appreciated!
Try blue or green pads on your 5680. You might have to do a 175 scrub first with neutral cleaner
or degreaser also to get it where you want. Then maintain with auto scrubber. They’re pretty much bulletproof though.
Reactions: Condog and SMRBAP
Condog
Tony
175 w/red or brown pad.
Portable or TM and a Hard Surface wand rinse @ 400 psi.
If a neutral pH cleaner doesnt cut it, try UltraPak Extreme
Can you use the 5680 vacuum only, instead of wand & TM (porty)?
