Don't do this
OVER???? Oh no....at the 1st odd smell.....YOU SIR.....will be on the hook
For all that mold ......NOW go lay that on yor helper.....he needs another couple days off......
None your paying enough already it was an accident unless they ask.
So it's going to cost me $850. The hose sprayed water onto the garage door motor and needs replacement.
The hose connection at the bibb was leaking a little while the work was being done. The pressure within the hose increased once the water stopped flowing out and was able to create a jet of water to soak the motor. I told my son, That's why I never allow a hose to leak and I fix the problem before it creates a bigger problem.
The helper who attached the hose is having a mental breakdown now.
My son and I told him It's Not his fault. He had no idea this could happen. My son told him it could have happened to him or anyone. I said, Well sorta-- It's never happened to me because to don't allow the hose to leak-- cuz I fix the issue first.
It's a training moment.-- aka School of Hard Knocks.
Good thing the water damage wasn't more severe.
How much discount should I give the customer as well?
This is EXACTLY why I show up with 185 gallons of pure, R.O. water on the job.
Fresh, purified water to clean Mrs. pilfingtons carpet, upholstery, or T&G…
No BS, no hook up, no dumping.
Clean, smooth operation from beginning to end.
I’ve NEVER had an issue.
Tell me again how having a large fresh tank is a problem???
Right, I have to replace my brakes every 5 years…
Hills and weight, break jobs
Papa John
Lifetime Supportive Member
John Stewart
It was a detached, unfinished garage with a slant on a hill. so the water drained out.
Reactions: SamIam
