chemical prime valve
Steve D
Steve D'Aquila
My chemical prime valve is leaking. There used to be a way to repack the valve with some type of cord as a maintenance routine. Does anyone know what I am talking about? Thanks
Glynn
Usually you can, remove the knob then slightly tighten the flats behind it.
Did you try just tightening the packing nut ?
often that's all it takes
