Auction 1 case Odorcide Smoke Brake
Auction includes:
  • 1 case Odorcide Smoke Brake (4x 1 Gallon)
  • Free shipping (ships to l48 only)
Odorcide® Smoke Brake works, and it’s easy to use. Designed for the worst tobacco AND marijuana odors. Odorcide® Smoke Brake is a Professional Strength Odor Eliminator that eliminates smoke odors from carpet, upholstery, walls, cars & more. Works best with a pump-up fine mist sprayer or fogger. Odorcide® Smoke Break has a pleasant fragrance that dissipates as it dries. Gallon concentrate makes 32 gallons at full strength.
$210+ Retail value
Starting bid $120
Minimum bid increment $2
Auction ends Thursday July 14th at 9PM EST/ 6PM PST
Can you wet fog it?
FOGGER SYSTEMS
Remove all unattached items such as drapes, rugs, furniture, etc. from the affected area and treat with Odorcide® Cigarette Smoke according to the directions below. Close all windows & doors, cover any sensitive items that can’t be removed and turn on the central heating/air conditioning system. Dilute product per instructions and add to the fogger, carefully following the directions supplied with the unit. Ensure all people and pets are out of the area.
Reactions: SamIam
FOGGER SYSTEMS
I saw that I use the smoke cide with a wet fogger it's good
