What are the chances?
I've never seen my coolant reservoir overflow in any vehicle I have ever owned. Last night we get our first frost, and this morning at our first job I see a puddle of orange coolant coming out from underneath my van. Seems like an obvious case of a frozen/ruptured heat exchanger right?
I did run a space heater in my van last night, but I didn't get home from a friends house until 11:30pm, and it was about 36 degrees outside when I plugged it in. I know water starts expanding at 39 degrees but I figured the van is at least 1 or 2 degrees warmer inside than the outside temp, so I figured I was fine and I'll just be more diligent moving forward. But then the terrifying orange puddle this morning 😬🄺
But! I ran my TM and was running water out of the solution line and it just kept coming out crystal clear, and as I was running the machine I watched my coolant reservoir and despite being filled to the top, it didn't leak another drop of coolant out of the overflow tube šŸ¤” I ran the TM for 2 hours at our first customers house and kept checking it and it didn't leak anymore coolant on the driveway. Now I'm not sure whats going on... Could it of been freaky timing for the coolant reservoir to coincidentally overflow the morning after our first frost and have nothing to do with a blown heat exchanger? Or is it more likely sneaky damage to the HX that will show more over time? If it was the former and something simple like an air pocket, that was a gift from God and a good reminder to not drop the ball on keeping my van warm! If it's the latter, well, that's seriously disheartening...
Yep, next stop coolant is leaking out of the reservoir onto the driveway when I pull in. Yet when I fire up the TM it doesn't leak any onto the driveway, the leak completely stops. If the HX was ruptured from a freeze, wouldn't the pressurized fresh water flowing through it cause even more coolant to leak out of the reservoir while the TM is running???
Every time ive blown a heat exchanger. The coolant level would rise when the machine was running and stay at that level till i ran the machine again and would raise again under pressure. You might want to check your radiator cap i can be a problem as simple as that. If the coolant is expanding into the tank but the cap isn't allowing it to return to the radiator as the van cools the expansion tank can over fill. Without being there and seeing it i couldn't tell you. When you say a puddle are we talking drops,ounces, cups,quarts, or gallons?
When the van is cold, remove the radiator cap and look inside. Is the radiator full or low?if full and your expansion tank still overflows, you probably have a high pressure leak. If low it's probably a problem with the van. Do you own a cooling system pressure kit? If not, Perhaps you can rent/ borrow one from local auto parts store
Have you tested your coolant to see if it's been diluted?
I don't see anything leaking from the water pump, the water pump is brand new too. The thermostat housing has a small leak, yea I fixed it last weekend and yet I didn't fix it, I need thermostat rtv dangit, lesson learned! When I arrive at a house I seem to lose about a pint or more of coolant on the driveway. It seems to continue dripping from the overflow hose until I start the TM and then it stops. I'll check the radiator fluid level when I get home today. Good call Dwain-o, if the radiator is full I have a high pressure leak probably from the HX, and if it is low I have a problem somewhere on the van/engine side. I don't have a pressure kit. Maybe I'll grab one.
Are you certain the thermostat was put on correctly and not upside down?
Youll want to wait till the engine is cold to look inside the radiator that way all the coolant has shrunk back down(for lack of better words) also note condition of hoses before removing radiator cap are they still round shaped or collapsed under vacuum? A telltale sign of a defective radiator cap
My engine temp is steady at 210 while the van is running, and it comes up to running temp as quickly as usual in the morning. I am fairly certain the thermostat is in correctly based on my memory of putting it in and how the van is running.
I'll check more things when I get to my next job and then more at home tonight once it cools down. Hopefully she keeps enough coolant to keep from overheating, if it isn't being flooded by a busted HX.
Im leaning more twards something simple apposed to a frozen heat exchanger. Given the amount/volume of coolant and soulition in that heat exchanger you just installed i would expect to see alot more damage before that thing froze. Meaning lines to and from it and all around that machine, blown/or pressure pump problems b y pass regulator problems. Things that are smaller and would take less to freeze. Mimd you im no expert on freezing. Where i live the temp rarely goes below 40 or above 78. And all the heat exchangers ive lost were from over pressure and age on copper not freezing. But over the decades i have lost heat exchangers. And it doesn't matter how the blow the out come is the same and they troubleshoot the same
  • Love
Good insights Dwain, and it soothes my troubled mind. I don't know much, but my guess is that if the HX was bad I'd be seeing the opposite of what is happening now, the TM running would cause more coolant loss not less (actually none). What freaky timing with this.
There's certainly more to figure out later, but I am going to take it as a blessed warning flare to keep my van toasty this winter. I am a guy that is prone to anxiety. Good opportunity to practice doing my best and then living like a lilly of the field.
A few minutes of prevention is definitely worth more than several thousand dollars worth of cure.
I doubt your HX is busted. I don't know the exact plumbing on your hydra master with the coolant, but I think it's a small problem. The temperature you described wasn't low enough to bust a heat exchanger, which is why I"m looking more at the van's engine being the culprit. Did you ever install a burp valve on top of that HX? An air pocket does cause the coolant reservoir to fill to the max/overflow, so I think that's the problem. Finding that pocket of air in your system might be a hassle with that aftermarket HX
But for a future safety on freezing: Stuff a rag up in your blower's exhaust pipe to prevent any cold air from blowing in the exhaust heat exchanger. It has nothing to do with your coolant heat exchanger, just a good practice
  • Love
Thanks Woody. I did install a burp valve on the high point of my HX. I have to drain the system and seal my thermostat housing with some goop tomorrow. I'll burp the system very thoroughly then. I find to even get coolant to circulate back to the HX I need to remove the burp valve and pour a gallon or so of coolant directly in the HX after draining the system. I got a special funnel kit Nate recommended for burping from the radiator cap. I'll go back and forth to work it all out. Hopefully thats all that is going on. Brilliant tip about protecting the Salsa HX! The cold air would've gotten right inside it with the silencer exhaust wide open.
I didn't see any collapsed hoses, I'm about to go open the radiator cap in a few minutes to see if its is filled to the top or low on coolant for a final confirmation this isn't the HX.
What ya find?
I find that I am getting old. "I'm going outside in a little bit to check the coolant", then proceeds to fall asleep....
And I slept in! I'm going to go check in a little bit, seriously this time I'm really doing it!
The coolant level in the radiator was low, and the hoses were not collapsed in at all. For today I think I am going to buy a new radiator cap, fix the leaky thermostat housing with my special goop, and burp the system more properly. If I still have problems after that I'll rent the pressure testing kit.
Im 99% sure your radiator cap is the problem. Something is gooping up or somehow not allowing the vacuum check valve to open so coolant expands and moves into the expansion tank when hot and as the engine cools it contracts creating a vacuum and is sucked back into the radiator. If the vacuum (return check valve) doesn't open than the coolant is trapped in the expansion tank. Now the other 1% can be a leak in the system where as the engine cools it draws air in instead of the coolant. Also compression leak can over pressurize the cooling system and blow coolant out. I would've been 100% sure that it was your cap had the hoses been collapsed but if you fix the leak at the thermostat and your oil doesn't have any coolant in it(be sure to.look inside of the oil fill cap )if inside the oil fill cap has a little moisture probably no a problem could be short trips motor didn't heat up enough to evaporate moisture pulled in thru the crankcase ventilation system. However I don't believe this is the problem because of the fact that temperature remains normal and additional coolant doesn't blow out during normal operations. But if there's alot of white greasing goop there could be signs of bigger problems. Im not telling you this to frighten you rather more of an opportunity to educate in trouble shooting so if this is a simple fix maybe the sky won't be falling and expensive parts aren't dying be the frist thing that comes to mind next time
  • Love
scotty747
Running the TM would definitely over fill the tank every time. Constant water being pushed into the cooling system. I'v had to replace radiator caps. Make sure you don't mix gm coolant with non gm, it will gel up.
  • Love
Thanks guys! I don't see any evidence of motor oil in the coolant or coolant/moisture in the motor oil. I looked at my old radiator cap closely when I replaced it with a new one and the 2 orings on the upper and lower portions of it were hardened and compressed compared to the new one I bought. Not sure if that would have much to do with it, or if the vacuum check valve component is more likely to fail, but a new one is in place now. I'm waiting until tomorrow or Monday (oh yes, 3 day weekend!) to fill the coolant system and burp it to allow the thermostat rtv time to cure.
I am heating both my van and my trailer when parked at home now. I got 2 of these sweet greenhouse thermostats to turn a small space heater on and off at whatever temp I set it at, I'll probably go for 45 degrees. I know from experience that electronic appliance thermostats fail randomly and regularly.
And I have 2 of these Marcell wireless temperature and power monitors that send alerts to my cell phone if power goes out or the temp drops below whatever range I have it set to. I used 1 in my trailer last winter and it worked great, just got a second one for the van. They operate on cellular networks and cost about $10/month for each unit. I subscribe to it from October until April. Setting it all up this weekend. Looks like the temps will be well above 40 degrees the next several nights here.
Sounds
Sounds like you gotta solid plan
  • Love
I'm thinking of shutting the van down mid November. The thought of my van breaking down on the road and freezing bothers me. I built my business with a portable. I think I'll run my portable operation from my insulated trailer for the coldest months of winter and fire the truckmount up again sometime in April. I'll run windshield washer fluid through the system but still keep the heat going in it all winter.
If that works for you, as I've said i have no experience with extreme weather too hot or too cold. But. I personally couldn't go back to operating a portable after running a truckmount. Even back in the 80's when my backup was a portable. I never used it after running a tm.
Ask around , how do other cleaners do it in the winter? Im pretty sure they don't just shut down? I doubt if many have portables settin around?Do they carry small propane heaters in case of a breakdown? Maybe setup to blow air thru the system to flush out the water? Propane heater on a 20lb bottle would be my first thought
Screenshot_20251011_183102_Chrome.jpg Screenshot_20251011_183044_Chrome.jpg Screenshot_20251011_182853_Chrome.jpg
I haven't used small propane heaters like the Mr Buddy, just full size ones in my garage. I bought a brand new Mr Buddy for my trailer and portable setup a while ago and the thing didn't work right out of the package. When I went online reading about them it seemed like they can be counted on to fail. I don't know what was wrong with the one I purchased but I returned it. It was a disheartening experience and since then I have just checked off small propane heaters as a possibility. I think the safety features on them often cause them to fail.
I'd probably have better luck carrying around my Honda 2200 watt inverter generator and my electric space heater. Although that is heavy and takes up quite a bit more space.
